Oil pressure gauge |
Ben Nichols |
Apr 19 2019, 09:05 AM
Newbie Group: Members Posts: 22 Joined: 12-February 19 From: Southampton UK Member No.: 22,873 Region Association: Europe |
Hi
I am looking to fit an oil pressure gauge using the existing sender. I can find 52mm VDO gauges which I am happy with, I will have to make a new centre console board to fit it. Question is do I need 0-5 bar or 0-10? Cheers Ben |
914forme |
Apr 19 2019, 09:10 AM
Ben (IMG:style_emoticons/default/confused24.gif) depends on the scale of the gauge. VDO makes different senders for different gauges, but most of the time they overlap to a degree from the metric bar line and the US PSI version it is the same sending unit. The difference comes in the scales and ohm ranges to make the scale.
They are listed by the scale, and ohm range so you can match it to the gauge. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:59 PM |
