| JFG |
Apr 20 2019, 12:36 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
The ignition barrell stuck inwards today after taking the key and would let the key back in until it popped out.
Is this an easy fix? squirt of silicone spray or something? |
| ctc911ctc |
Apr 20 2019, 04:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
I have the same thing, a few weeks after replacing the ignition switch.....have not gone back in yet.
The ignition barrell stuck inwards today after taking the key and would let the key back in until it popped out. Is this an easy fix? squirt of silicone spray or something? |
| 914Sixer |
Apr 21 2019, 11:36 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,432 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Original had some white grease in there. The lock slide is what may need grease. Lock has to be pulled to do that. More than likely the plastic ignition portion of the lock has broken, not letting the spring return.
| Dave_Darling |
Apr 21 2019, 12:35 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Mine will do that sometimes; I just wiggle the key and it pops out. I probably should get around to replacing it some time.
--DD |
| bandjoey |
Apr 21 2019, 08:29 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
A really worn key will also cause a sticking key. A light lube not to attract dirt is best...a real locksmith uses dry graphite. A real locksmith can either read the cuts on your old key and code cut a new one, or cut a new key to say, the trunk lock.
Spoke ( i think that's him) offers a complete lock and key rebuild service too. |
| wndsrfr |
Apr 21 2019, 09:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
The ignition barrell stuck inwards today after taking the key and would let the key back in until it popped out. Is this an easy fix? squirt of silicone spray or something? Next time it happens just jiggle the steering wheel a bit and it will likely pop out...I think it's the steering wheel lock that is a bit sticky... |
| dr914@autoatlanta.com |
Apr 22 2019, 07:20 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,231 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
there is a small spring under the black y shaped cover. Lube the lock barrel and clean the spring perch and it should work just fine again
Lo-Fi Version | Time is now: 11th March 2026 - 01:50 AM |
