Gauging interest...pun intended, Semi-custom wired Wide Band O2 meter, AFR |
Mark Henry |
Apr 21 2019, 09:03 AM
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing. I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness. Attached image(s) |
mb911 |
Apr 21 2019, 01:41 PM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Mark,
I think I would be in.. I need something and currently have nothing so this would help. |
Mark Henry |
Apr 21 2019, 02:20 PM
Mark, I think I would be in.. I need something and currently have nothing so this would help. Ben we'll talk, you may already offer this as an option, but I'd like you to offer the bungs welded in on you're headers/exchangers. I have MSDS headers but the placement just pass the collector should be the similar. The tangerine /4 header I have here has a bung welded in I'll have to mock up a /4 to see the location. I want, not only for myself, but to have the perfect locations for peeps to mount the lambda on their exhaust. My headers are ceramic coated how far do I have to grind the coating back to weld my bungs in? I want to do as little as required. 1/4 inch? |
Lo-Fi Version | Time is now: 5th May 2024 - 03:41 PM |
