Gauging interest...pun intended, Semi-custom wired Wide Band O2 meter, AFR |
Mark Henry |
Apr 21 2019, 09:03 AM
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing. I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness. Attached image(s) |
tmessenger |
Apr 21 2019, 08:03 PM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
I bought one of these for my car a couple of months ago. A couple of things I like about it:
It reads and displays the OX sensor temperature. If you make up the gauge connector after you run the wire through the tunnel the hole size into the tunnel is very small. I drilled a 3/8" hole for a grommet and this worked great to run the wire through. I've attached a chart I've made up for 100% petrol that I can buy in Iowa (no ethanol) Note: The idle circuit on my cars carbs as it came to me were way rich so I am now working out the correct jets. Tim Lambda__A_F.pdf ( 31.42k ) Number of downloads: 45 |
Lo-Fi Version | Time is now: 5th May 2024 - 08:34 PM |
