Gauging interest...pun intended, Semi-custom wired Wide Band O2 meter, AFR |
Mark Henry |
Apr 21 2019, 09:03 AM
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing. I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness. Attached image(s) |
mb911 |
Apr 21 2019, 07:28 PM
914 Guru Group: Members Posts: 6,825 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Mark Henry |
Apr 22 2019, 05:17 AM
Mark , 1/4" should be perfect. I just did this on a 15 year old m&k muffler for a customer.. Here are the stepped headers I built for my car.. I will build heat exchangers over them after some testing but notice my 02 bung location. The bung should be clock to the 10 or 2 o'clock, it's the best position for any moisture to fully drain out of the o2 sensor. Moisture can cause thermal shock to the sensor. |
Lo-Fi Version | Time is now: 6th May 2024 - 02:56 AM |
