Gauging interest...pun intended, Semi-custom wired Wide Band O2 meter, AFR |
Mark Henry |
Apr 21 2019, 09:03 AM
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing. I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness. Attached image(s) |
Mark Henry |
Apr 22 2019, 12:41 PM
Maybe I'm wrong or misinformed, wouldn't be the first time... the 14point7 instructions says between 10 and 2 o'clock.
About 3 feet from the exhaust or turbo outlet. |
Lo-Fi Version | Time is now: 5th May 2024 - 05:19 PM |
