Gauging interest...pun intended, Semi-custom wired Wide Band O2 meter, AFR |
Mark Henry |
Apr 21 2019, 09:03 AM
I'm making up several 14point7 SLC free 2, WB O2 meters for customers and myself and just wondering if this would be of interest to the brotherhood.
Problem with most O2 meters is the wire harness, most of the time they are just a bit short for a clean rear/mid engine install. The wires are often cheaper quality loose wire covered with the Chinese finger puzzle like plastic sheathing. I'm using a high quality sheath, twisted, 6 wire with shrink wrap tubing on the ends, for the main harness. Attached image(s) |
Mark Henry |
Apr 21 2019, 12:42 PM
I likely could make each one around $10 cheaper using loose wire and the braided plastic covering.
Not near as nice as the UL grade cable I'm using. The braided covering is also too expensive locally, to get the price brake I'd have to order it from china, ETA 8 weeks. Attached image(s) |
ctc911ctc |
May 15 2019, 11:20 AM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Ready to ship yet?
[ quote name='Mark Henry' date='Apr 21 2019, 12:42 PM' post='2707440'] I likely could make each one around $10 cheaper using loose wire and the braided plastic covering. Not near as nice as the UL grade cable I'm using. The braided covering is also too expensive locally, to get the price brake I'd have to order it from china, ETA 8 weeks. [/quote] |
Lo-Fi Version | Time is now: 5th May 2024 - 03:26 PM |
