Installing Front Trunk Seal Question, Front Trunk Seal Installation and Drain |
Highland |
Apr 21 2019, 07:31 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So read some old threads trying to figure out how to install the front trunk seal from 914Rubber. It seems that many install with no adhesive for maintenance purposes, but I'm having trouble getting the seal to stay in place.
So some remedial questions: 1) Does this picture show the bottom (facing the ground) of the seal or do I have it backwards? 2) Do most people use weatherstrip adhesive? maybe just in the corners? 3) Can somebody post a picture of where this part goes? I don't seem to be able to find a picture anywhere. |
bandjoey |
Apr 21 2019, 08:20 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
So read some old threads trying to figure out how to install the front trunk seal from 914Rubber. It seems that many install with no adhesive for maintenance purposes, but I'm having trouble getting the seal to stay in place. So some remedial questions: 1) Does this picture show the bottom (facing the ground) of the seal or do I have it backwards? 2) Do most people use weatherstrip adhesive? maybe just in the corners? 3) Can somebody post a picture of where this part goes? I don't seem to be able to find a picture anywhere. #3 is the rain drain tube in the headlight tubs, under the lights. There's a hole there that it plugs into. #1 the small side of the weather seal goes on top and the larger side on the bottom in the channel. I do not glue mine in and after a rain or car wash I pull it out to dry the channel. Glued I think it can trap water under the seal. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:09 PM |
