Ball socket / throttle cable, Ball socket / throttle cable |
HerdofCrickets |
Apr 23 2019, 09:03 PM
Member Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
I'm attempting to replace the throttle cable because it broke on the carburetor side.
Are there any tricks to removing the ball socket? I've tried to pop it off with a screwdriver and no luck. |
Chi-town |
Apr 23 2019, 09:41 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Use the 8mm jam nut and turn it like you're trying to tighten it, it should pop off
HerdofCrickets |
Apr 24 2019, 05:45 AM
IronHillRestorations |
Use a 7 or 8 mm thin ignition wrench and put it between the ball stud and socket and pry it off
HerdofCrickets |
May 4 2019, 12:57 PM
Okay, so I got the dumb thing off easily enough. What's the trick to putting that ball socket back on?
Chi-town |
May 4 2019, 02:51 PM
Push hard
HerdofCrickets |
May 4 2019, 02:56 PM
Mark Henry |
May 4 2019, 09:42 PM
Wrong end of a screwdriver, something to push on it that's harder than your thumb.
Or tape up some pump pliers. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:41 AM |
