2 Pages V < 1 2
> Power for amp?, Best and easiest place to pull power from?
VegasVic
post Jun 1 2020, 10:01 PM
Post #21
QUOTE(Steve @ Jun 1 2020, 08:38 PM) *
QUOTE(VegasVic @ Jun 1 2020, 05:05 PM) *
Would you elaborate on your specific routing?
It’s been a while but, I ran the wire through the speedometer grommet and then out the same hole the harness goes through on top of the tunnel. I routed it along side the other wires. I think I followed the harness pass the fuse box and into the front trunk, where, mounted the main amp. I also spliced that same wire for a powered sub woofer in the car.
Great! Thank you!
porschetub
post Jun 2 2020, 06:04 PM
Post #22
Did the same as Steve mentioned ,I used small positive cable but larger than the stock wiring gauge to the battery.
This thread has been real handy as I know little about subs/amps and learning here.
I have the Hella 4 fuse aux block ,no point in overloading the somewhat minimal stock fusebox afterall.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 3rd March 2026 - 10:12 AM
