| Tdskip |
Apr 26 2019, 08:02 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Looking to learn more about our engines, I've found rebuild guides to be a great resources on some of my other cars.
Is there a go-to source for these you can recommend? Thanks! |
| Beebo Kanelle |
Apr 26 2019, 08:12 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
Mr. Raby's "Type 4 Rebuild DVD" is an excellent primer if you're completely unfamiliar the the Type 4 engine... at least it was for me.
In fact, it's great if you have no intention of rebuilding, but instead just want to learn. |
| JOEPROPER |
Apr 26 2019, 09:13 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
Mr. Raby's "Type 4 Rebuild DVD" is an excellent primer if you're completely unfamiliar the the Type 4 engine... at least it was for me. In fact, if great if you have no intention of rebuilding, but instead just want to learn. (IMG:style_emoticons/default/agree.gif) +1 on the Jake Raby video. |
| mgphoto |
Apr 26 2019, 09:47 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,491 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Wilson VW engine rebuild book is great, a lot of type 1 info but a good amount of type 4, both engines are very similar. There is a VW engine hot rod book by the same publisher, lots of formula Vee stuff.
Jakes video is really good but the sealant technology has changed dramatically. |
| 914Sixer |
Apr 26 2019, 09:49 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,516 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
If you want a book that will really give you all the background information, Tom Wilson's book covers it all. It does a a side by side comparison of each type of VW engine. Great learning curve. Breaks type 4 engines down to show what is common. Notes on what makes the 914 different. Then it will tell you how to put it together.
| maf914 |
Apr 26 2019, 09:58 AM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
In the pre internet days I rebuilt my Type 4 engine using the Hayne's 914 manual, Clymer 914 manual, and Tom Wilson's VW Aircooled Engine book. Now we have the internet and Jake Raby's Type 4 CD.
| maf914 |
Apr 26 2019, 10:00 AM
I wonder why my attachments stacked horizontally and not vertically? First time this has happened for me.
| Tdskip |
Apr 26 2019, 10:44 AM
Thanks gentlemen!
| cashiersjm |
Apr 26 2019, 11:10 AM
Member ![]() Group: Members Posts: 41 Joined: 6-December 09 From: Hendersonville, North Carolina Member No.: 11,100 Region Association: South East States
Does Jake Raby still sell the video or where can it be purchased?
| rhodyguy |
Apr 26 2019, 11:12 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Bug Me Video.
| bbrock |
Apr 26 2019, 11:17 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Just a quick word as someone who has used both Haynes and Tom Wilson's books to rebuild engines. The Haynes is barely adequate to get the job done and is missing some stuff that you may regret not knowing later (like reusing old valves might grenade your engine (IMG:style_emoticons/default/headbang.gif) ). Wilson's book is WAY better but lacks some information I've learned from this group about things that contribute to a quality build. Things like decking the case to make sure cylinder registers are even and perpendicular to the crank, and cc'ing heads for getting the compression ratio you want when setting deck height.
I'm not knocking those books. They are great (especially Wilson's book). I just wanted to share my experience of what was missing that I wish I had known. |
| Superhawk996 |
Apr 26 2019, 11:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,944 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Just a quick word as someone who has used both Haynes and Tom Wilson's books to rebuild engines. The Haynes is barely adequate to get the job done and is missing some stuff that you may regret not knowing later (like reusing old valves might grenade your engine (IMG:style_emoticons/default/headbang.gif) ). Wilson's book is WAY better but lacks some information I've learned from this group about things that contribute to a quality build. Things like decking the case to make sure cylinder registers are even and perpendicular to the crank, and cc'ing heads for getting the compression ratio you want when setting deck height. I'm not knocking those books. They are great (especially Wilson's book). I just wanted to share my experience of what was missing that I wish I had known. Agree - recommend both books. However, remember VW's are notoriously robust engines. The points you make differentiate a great rebuild from an average one. I used both books referenced when I rebuilt my 1.7L to a 1.9L back in early 90' or 91' and didn't put in the attention to detail ( like decking the case, line boring, etc) and my engine went about 80,000 miles with no issues. Tough little buggers! (IMG:style_emoticons/default/aktion035.gif) I had a early 70's VW bug (flat windshield) with a type 1 engine. Bought it for $50. After a few months of owning and driving it, at the gas station I noticed a huge puddle of oil had formed under it. Looked under it. No source of oil leakage. What the heck? Started it and then looked under it. One of the cylinders was moving back and forth and when it moved out from the case, oil was leaking like mad. Popped off the valve cover, tightened the bottom four cylinder head nuts. The top 4 can't be reached without pulling the tin so I had no choice but to leave them. Being poor, in college, and lacking a place to properly fix it, I drove it several thousand miles with only the bottom 4 bolts tight. No more oil leaks. down on power some but it ran pretty darn good for about a year before I finally dropped the engine. Even then I just tightened up the upper head nuts and then ran it another couple thousand miles before I finally sold it for $75.00 to a guy that was using it for a sand rail donor. Moral of the story - tough little buggers! (IMG:style_emoticons/default/lol-2.gif) |
| Dave_Darling |
Apr 26 2019, 11:56 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,355 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
They're all good, but none is perfect. If nothing else, they were written a while ago, and the parts have gotten older and technology has gotten better. And more expensive in many ways.
One part of Wilson's book that was particularly confusing to me is where he talks about the cam timing marks. He addresses all of the engines in one paragraph, which makes it very easy to mix up what you're reading. You can cross-check with the Haynes manual or just remember that the one marked tooth on the one gear goes in between the two marked teeth on the other gear... The Raby video is pretty good for showing you what happens when you have no surprises, and when a team of elves gets everything cleaned up and prepped ahead of time. Then again, the video would be about thirty hours long if he showed us all of the various "surprises" he found, and another forty hours long if he showed all of the cleaning and prep... (IMG:style_emoticons/default/wink.gif) Combine a couple of the above-mentioned sources with this forum, though, and it should work out pretty well. --DD |
| bbrock |
Apr 26 2019, 02:48 PM
Agree - recommend both books. However, remember VW's are notoriously robust engines. The points you make differentiate a great rebuild from an average one. Absolutely! and as fantastic as it is, Internet advice sometimes leans toward dogmatic which makes it difficult for a dummy like me to know what must be done for any decent build and understanding the benefits and trade-offs of the other things. I could expand on this with examples but won't. |
| Tdskip |
Apr 27 2019, 06:16 AM
Ordered Wilson’s book, should make for some good reading.
Thanks! |
| fixer34 |
Apr 27 2019, 11:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Back in my VW days (late 60's/early 70's) I always had John Muir's book handy. Not much on pictures, but the non-technical way he explained everything was pretty cool. I still have that book around someplace.
| settador |
Apr 28 2019, 12:05 PM
Newbie ![]() Group: Members Posts: 31 Joined: 16-May 05 From: Lee, NH Member No.: 4,086 Region Association: None
Wilson's book, John Muir's idiot guide, and a shop manual.
In 2005 a guy here on 914 world named Mike Rose sent me a complete shop manual, including schematics and fuel injection, on a CD. Didn't ask for a penny in return, so I burned him a CD of "driving music" and sent it to him. I have the info in a file on my computer and I'm happy to pay it forward if anyone is interested. |
| Jake Raby |
May 23 2019, 10:10 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I've contemplated doing a new T4 rebuild video. The original that I did 20 years ago is very dated. It was also more geared toward the VW bus, than the 914.
With today's technology, we can do a lot more than was possible 20 years ago. |
| doug_b_928 |
May 23 2019, 10:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 738 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I purchased, and plan to use, your video. It would be great if you do a new one or provide an update of what those of us who have the video could/should do differently than what you did in the video.
| Tdskip |
May 23 2019, 11:18 AM
I’d order an updated version too - I think quite a few of us will.
Lo-Fi Version | Time is now: 13th July 2026 - 07:01 AM |
