koni rear coilover question |
jhynesrockmtn |
Apr 27 2019, 06:55 PM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I'm toward the end of the process of putting koni coilovers on the rear of my 914-4 vintage race car. Probably a stupid question but I've searched and watched some videos.
How do you get the top nut to bite and tighten down without just turning the shaft? |
914Sixer |
Apr 27 2019, 07:25 PM
You have to have external top adjuster. Shock top must have blade to fit into adjuster
rgalla9146 |
Apr 28 2019, 09:04 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
There is a proper shock absorber socket to hold the the shaft.
The usual approach is a electric or air impact. Or hold with a vice grip. Attached thumbnail(s) |
jhynesrockmtn |
Apr 28 2019, 12:12 PM
There is a proper shock absorber socket to hold the the shaft. The usual approach is a electric or air impact. Or hold with a vice grip. Thanks all, the top of the koni has a small nut and the blade adjuster. I was worried about putting too much pressure on the small nut but once I got brave enough it worked. |
rhodyguy |
Apr 28 2019, 12:39 PM
You need a deep well socket with the ext adj using a impact. Securing the washer with the tang, channel lock, allows you use the open end.
Lo-Fi Version | Time is now: 17th May 2024 - 07:00 PM |
