Wiring for an Engine Run Stand with DJet |
doug_b_928 |
May 6 2019, 07:32 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I'm building an engine stand that will serve multiple purposes (transport, storage, installation/removal, and testing/break-in). The one part I have very little clue about how to do is the wiring. I've searched the forum and have seen others express an interest in having wiring info for a test stand, but it doesn't seem to be documented anywhere. So, hopefully this thread will help not only me, but also anyone else in the future who is looking to do the same.
I'm going to have the djet 'computer', manifold pressure sensor (MPS), decel valve, fuel pump, and regulator plate/relay board mounted to the stand. The ground that normally connects the battery/engine to the chassis will be grounded to the stand. The wiring for the MPS will be connected to it and the wiring for the fuel injectors, alternator, and 12 pin connector will all be connected to the regulator plate. In other words, it is as if the engine were in the car with the exception of the wiring connections at the 14 pin connector on the regulator plate. On the stand's 'dash board' I think (please correct me if I'm wrong) I need an ignition toggle switch, a momentary starter switch, an oil pressure 'idiot' light (I'm getting a cheap LED light on sale tomorrow), a tachometer (I have a cheap, generic one from FLAPS), and lever with a cable for controlling the throttle. So the question is, what is the correct way to wire these items? I have the figures from Jeff Bowlsby's webpage and the wiring diagrams. What I'm missing is the theory of what I need to do wiring-wise to make the engine run and get the feedback to the tachometer and idiot light. I'm hoping others who appear to have done this can chime in with their thoughts (paging @StratPlayer @VaccaRabite @michelko @mb911 @barefoot ) and wiring gurus (like @JeffBowlsby ). I assume I run wires from the battery to the two power pins on the 14 pin connector, so that the regulator plate has power. After that, although I think it should be pretty simple, I'm not 100% on how to wire the ignition, starter, tach and idiot light to the 14 pin connector. Please advise. |
doug_b_928 |
May 11 2019, 08:59 AM
I'm making good progress on the stand, but have a question re the schematic: Just to confirm my understanding of the schematic and the wiring diagram, the two supply voltage lines that come from VCC and go to pins 12 and 14 only supply power via the relay board to the Fuel Pump and the Fuel Injection Power Connector, correct? In other words, this is why VCC still needs to be supplied directly to the ignition, oil pressure light, generator light, tachometer, and starter, but not to the fuel pump).
P.S. In thinking about my previous comment re the fuel pump fuse, I realized that it's obvious I can just put a toggle switch between pin 13 and the fuel pump + to control power to the fuel pump separately. |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:43 PM |
