Odyssey Battery Question, Negative Terminal Rotates Slightly |
saigon71 |
May 12 2019, 02:11 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I've been battling a poor running vehicle all season. It appears to be electrical. While checking my battery connections, I noticed that the negative battery terminal on my brand new Odyssey 925 will rotate about 1/8".
I removed the screw on post and verified that it is the battery terminal itself, not just the screw-on SAE top. Here is a video: https://www.youtube.com/watch?v=_uOT0vKlyMc Is this normal? The positive side does NOT move. Thanks. |
914-d |
May 12 2019, 02:33 PM
Newbie Group: Members Posts: 37 Joined: 6-June 13 From: nor cal Member No.: 15,974 Region Association: Northern California |
There should an allen head bolt inside the hole on the terminal, as they are removable...tighten it
sithot |
May 12 2019, 02:36 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
There should an allen head bolt inside the hole on the terminal, as they are removable...tighten it (IMG:style_emoticons/default/agree.gif) |
saigon71 |
May 12 2019, 03:11 PM
There should an allen head bolt inside the hole on the terminal, as they are removable...tighten it (IMG:style_emoticons/default/agree.gif) This video shows more clearly what is happening. It's actually the negative post coming out of the battery that is moving. https://www.youtube.com/watch?v=UGIkZaj_P1c |
Lo-Fi Version | Time is now: 1st May 2024 - 09:35 PM |
