Odyssey Battery Question, Negative Terminal Rotates Slightly |
saigon71 |
May 12 2019, 02:11 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I've been battling a poor running vehicle all season. It appears to be electrical. While checking my battery connections, I noticed that the negative battery terminal on my brand new Odyssey 925 will rotate about 1/8".
I removed the screw on post and verified that it is the battery terminal itself, not just the screw-on SAE top. Here is a video: https://www.youtube.com/watch?v=_uOT0vKlyMc Is this normal? The positive side does NOT move. Thanks. |
Mark Henry |
May 12 2019, 03:22 PM
Is it the internal part of the post? if it is not good.
I'd take the post off and confirm this. |
saigon71 |
May 12 2019, 06:09 PM
wndsrfr |
May 12 2019, 08:29 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Is it the internal part of the post? if it is not good. I'd take the post off and confirm this. Yes, it's the internal part of the post. What you see in the 2nd video is just an allen head bolt installed so I can twist it. Claim it on warranty...who was the vendor? Odyssey should stand behind it. |
saigon71 |
May 13 2019, 01:22 PM
Is it the internal part of the post? if it is not good. I'd take the post off and confirm this. Yes, it's the internal part of the post. What you see in the 2nd video is just an allen head bolt installed so I can twist it. Claim it on warranty...who was the vendor? Odyssey should stand behind it. Bought it from Amazon. Their return window has closed, so I'm going directly to Odyssey. |
Lo-Fi Version | Time is now: 1st May 2024 - 08:50 PM |
