FS: Porsche 2.8 Engine 46IDA, 92mm RSR Pistons, Twin Plug |
MrBMW2002 |
May 13 2019, 11:21 AM
Newbie Group: Members Posts: 5 Joined: 25-July 10 From: California Member No.: 11,976 Region Association: None |
I am selling a Porsche 2.8 Engine. I was never given any of the build receipts, records or any other documents with the engine but here are the details that I do know.
Here are some pictures http://s263.photobucket.com/user/MrBMW2002...Porsche28engine This engine is still installed in a 914 and it starts right up and is a very smooth engine. It makes great power, does not have any leaks, and appears that it has very little use on it. Here are the specifics. Built on a 1974 7R 911 Case Weber 46IDA3C Carbs Made in Italy. Matching L9 and K9 Twin Plug with Bosch Distributor and MSD goodies 92mm MAHLE RSR Pistons/Cylinders S Cams 1969S Aluminum Pressure Plate 916-6 Oil Cooler Updated Pressure Fed 930 Tensioners. Race Headers/Exhaust. This is a complete drop down engine assembly. Asking 12,500 for the engine or 15,000 for the complete engine/914 transmission with LSD, 914-6 oil tank etc. Attached image(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:37 PM |
