Rear View Mirror placement?, Anyone have the dimensions? |
Steve |
May 13 2019, 01:36 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I looked around, but was not able to find where you mount the rear view mirror on the windshield. Does anyone have the dimensions? Mainly from the top of the mirror patch to the bottom of the chrome around the top of the windshield.
Thanks in advance for the help!! |
Mark Henry |
May 13 2019, 02:43 PM
How do you remove the base? and stick it on?
My car the base is about 4" but the wife's is less than 2-1/2". |
Bartlett 914 |
May 15 2019, 06:32 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
How do you remove the base? and stick it on? My car the base is about 4" but the wife's is less than 2-1/2". I have been successful 3 time at this but it is risky. Heat will break down the glue. I use a Mapp gas torch that has instant start. I use a piece of sheet metal as a shield so I don't overheat the glass. I hold the torch parallel to the glass and heat the base in bursts making sure I don't get too much heat on the glass. I use a rotating motion on the mirror instead of pulling it. |
Lo-Fi Version | Time is now: 27th April 2024 - 02:01 PM |
