Rear View Mirror placement?, Anyone have the dimensions? |
Steve |
May 13 2019, 01:36 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I looked around, but was not able to find where you mount the rear view mirror on the windshield. Does anyone have the dimensions? Mainly from the top of the mirror patch to the bottom of the chrome around the top of the windshield.
Thanks in advance for the help!! |
porschetub |
May 14 2019, 03:23 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I marked the location on the outside of the screen with blue painters tape using the marks left behind on the inside,used a sharp blade to remove old clue on the inside and the mirror base and wiped contact areas with acetone.
I found the 944 stick on pad from Pelican worked a treat..still on there after 2 years. |
Steve |
May 15 2019, 07:11 AM
I marked the location on the outside of the screen with blue painters tape using the marks left behind on the inside,used a sharp blade to remove old clue on the inside and the mirror base and wiped contact areas with acetone. I found the 944 stick on pad from Pelican worked a treat..still on there after 2 years. Thanks for the tip!! I will use blue tape this time. |
Lo-Fi Version | Time is now: 28th April 2024 - 12:34 AM |
