More Novice Help Please, Suspension, CV Joint and Front Suspension Disassembly |
Highland |
May 13 2019, 03:20 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
More amateur help please, this time with CV joint and front suspension:
1) I've only taken apart one axle, but I found some pitting on one of the outside bearing. Pictured is the worse example: Can I address this by swapping the transmission end for the wheel end? I notice they ride in slightly different locations. 2) Having much trouble taking apart the front suspension. a) Can I just use a fork to pry this off or do I need a puller/pusher device? I have neither so trying to avoid buying both. Soaking in PB Blaster now. Boot is already torn so a fork would do no damage, just looking for the easiest way. b) According to the Haines Manual the bolt/pin shown is suppose to come out to release the ball joint (held in by a semi-circle feature?). Mine looks like it is permanently attached to the strut. How do I get it out? 3) When removing the control arms do the adjusters need to be wound loose? Can the cross support bar be left in place? |
mepstein |
May 15 2019, 06:57 PM
914-6 GT in waiting Group: Members Posts: 19,240 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I bought a pair of 911 struts super cheap because someone cut the ball joint shaft off with a saws-all and left the shaft stuck in the bottom of the strut. Took the struts into our shop and had a guy weld a big nut to the cut shaft. Clamped the nut in a vise and twisted the strut. Shaft popped out in 2 seconds. Welding the nut on heated everything up. So if you run into trouble, remember heat is your friend.
Superhawk996 |
May 15 2019, 07:33 PM
914 Guru Group: Members Posts: 5,750 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I bought a pair of 911 struts super cheap because someone cut the ball joint shaft off with a saws-all and left the shaft stuck in the bottom of the strut. Took the struts into our shop and had a guy weld a big nut to the cut shaft. Clamped the nut in a vise and twisted the strut. Shaft popped out in 2 seconds. Welding the nut on heated everything up. So if you run into trouble, remember heat is your friend. Where do you find all these crazies. A plywood floor and now someone that (IMG:style_emoticons/default/sawzall-smiley.gif) the ball joint stubs. (IMG:style_emoticons/default/aktion035.gif) |
mepstein |
May 15 2019, 07:38 PM
I bought a pair of 911 struts super cheap because someone cut the ball joint shaft off with a saws-all and left the shaft stuck in the bottom of the strut. Took the struts into our shop and had a guy weld a big nut to the cut shaft. Clamped the nut in a vise and twisted the strut. Shaft popped out in 2 seconds. Welding the nut on heated everything up. So if you run into trouble, remember heat is your friend. Where do you find all these crazies. A plywood floor and now someone that (IMG:style_emoticons/default/sawzall-smiley.gif) the ball joint stubs. (IMG:style_emoticons/default/aktion035.gif) I sold real estate for 15 years. The car stuff pales to what crazy stuff people do to their houses. |
Lo-Fi Version | Time is now: 27th April 2024 - 05:01 PM |
