More Novice Help Please, Suspension, CV Joint and Front Suspension Disassembly |
Highland |
May 13 2019, 03:20 PM
Senior Member Group: Members Posts: 511 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
More amateur help please, this time with CV joint and front suspension:
1) I've only taken apart one axle, but I found some pitting on one of the outside bearing. Pictured is the worse example: Can I address this by swapping the transmission end for the wheel end? I notice they ride in slightly different locations. 2) Having much trouble taking apart the front suspension. a) Can I just use a fork to pry this off or do I need a puller/pusher device? I have neither so trying to avoid buying both. Soaking in PB Blaster now. Boot is already torn so a fork would do no damage, just looking for the easiest way. b) According to the Haines Manual the bolt/pin shown is suppose to come out to release the ball joint (held in by a semi-circle feature?). Mine looks like it is permanently attached to the strut. How do I get it out? 3) When removing the control arms do the adjusters need to be wound loose? Can the cross support bar be left in place? |
Highland |
May 14 2019, 08:25 PM
What is the proper tool for removing the pin attaching the strut to the A-arm ball joint?
Picture would be great (IMG:style_emoticons/default/smile.gif) Do most just replace the ball joint? My boot is still solid, but is that the only criteria? |
914Toy |
May 15 2019, 02:07 PM
Senior Member Group: Members Posts: 710 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
What is the proper tool for removing the pin attaching the strut to the A-arm ball joint? Picture would be great (IMG:style_emoticons/default/smile.gif) Do most just replace the ball joint? My boot is still solid, but is that the only criteria? I used a tool like the one you got from Autozone - you may have to use some "spacers" like large washers or nuts to position it. |
Lo-Fi Version | Time is now: 29th March 2024 - 03:27 AM |
