More Novice Help Please, Suspension, CV Joint and Front Suspension Disassembly |
Highland |
May 13 2019, 03:20 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
More amateur help please, this time with CV joint and front suspension:
1) I've only taken apart one axle, but I found some pitting on one of the outside bearing. Pictured is the worse example: Can I address this by swapping the transmission end for the wheel end? I notice they ride in slightly different locations. 2) Having much trouble taking apart the front suspension. a) Can I just use a fork to pry this off or do I need a puller/pusher device? I have neither so trying to avoid buying both. Soaking in PB Blaster now. Boot is already torn so a fork would do no damage, just looking for the easiest way. b) According to the Haines Manual the bolt/pin shown is suppose to come out to release the ball joint (held in by a semi-circle feature?). Mine looks like it is permanently attached to the strut. How do I get it out? 3) When removing the control arms do the adjusters need to be wound loose? Can the cross support bar be left in place? |
mepstein |
May 16 2019, 07:35 PM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Usually, you only need to replace torsion bars if they are heavily corroded or worn a grove in the rod when the bushing fails. You do need to maintain the same sides as they started.
Lo-Fi Version | Time is now: 24th April 2024 - 07:24 PM |
