Trailing arm bushings, Install procedure for 914 Rubber bushings |
Morph914 |
May 13 2019, 07:48 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I purchased these along with my a arm bushings. I am about to install the a arm bushings and have a clear understanding of how to install those, but not the trailing arm bushings. I have watched a video on the trailing arm bushings install, but the type of bushing he was using is unknown unless I missed something. Do 914 Rubber trailing arm bushings get installed with grease? Are these rubber or teflon?
Thanks for any input, John |
Morph914 |
May 14 2019, 05:11 PM
Thank you.
Well, I thought I had everything I needed to install the a arm bushings, I did everything in the video to a T except using a temp gun to make sure the water was hot enough. I just figured a rolling boil for ten minutes should do the job. Apparently I thought wrong. I will say that the install tool should fit a little better than it does. Anyway, I’ll be ordering more bushings from 914 Rubber. |
Lo-Fi Version | Time is now: 25th April 2024 - 02:17 AM |
