Trailing arm bushings, Install procedure for 914 Rubber bushings |
Morph914 |
May 13 2019, 07:48 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I purchased these along with my a arm bushings. I am about to install the a arm bushings and have a clear understanding of how to install those, but not the trailing arm bushings. I have watched a video on the trailing arm bushings install, but the type of bushing he was using is unknown unless I missed something. Do 914 Rubber trailing arm bushings get installed with grease? Are these rubber or teflon?
Thanks for any input, John |
bbrock |
May 14 2019, 05:40 PM
Hey John,
I used electrical tape to wrap around the tools to take out the slop. IIRC, each end of the A-arm was a little different. Sorry you had bad luck on the first try. I didn't used a temp gun on the boiling water either but because I'm at altitude, I boiled them for a good 20-30 minutes. |
Lo-Fi Version | Time is now: 19th April 2024 - 03:01 AM |
