Trailing arm bushings, Install procedure for 914 Rubber bushings |
Morph914 |
May 13 2019, 07:48 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I purchased these along with my a arm bushings. I am about to install the a arm bushings and have a clear understanding of how to install those, but not the trailing arm bushings. I have watched a video on the trailing arm bushings install, but the type of bushing he was using is unknown unless I missed something. Do 914 Rubber trailing arm bushings get installed with grease? Are these rubber or teflon?
Thanks for any input, John |
mepstein |
May 14 2019, 08:42 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Boiling water only gets to 212 no matter how long you boil it so theres a point that it's technique and not just heat. Cuddy_K has a good video.
The guys at our shop use a rattle gun to zip it in. Less time losing heat than using a wrench. |
bbrock |
May 14 2019, 10:48 PM
Boiling water only gets to 212 no matter how long you boil it so theres a point that it's technique and not just heat. Cuddy_K has a good video. The guys at our shop use a rattle gun to zip it in. Less time losing heat than using a wrench. Well, not quite. If you live where I live, it will boil at 200F, which is why I boil it a little longer just to make sure it is at a full boil and max heat. But yeah, it isn't going to get any hotter than the boiling point for your elevation. |
Lo-Fi Version | Time is now: 25th April 2024 - 02:47 PM |
