Wheel options?, 4 x 130 15 inch after market wheel options. |
71six |
May 15 2019, 07:38 AM
Member Group: Members Posts: 135 Joined: 4-July 03 From: Fitzwilliam,NH Member No.: 884 |
Other than the factory wheels what are available in either 5.5 or 6 inch width with correct back spacing for a stock body 914?
Thanks, Mark |
thelogo |
May 16 2019, 08:13 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
I would go for the vto wheels
But its a little hard to believe They fit narrow body car s |
sixnotfour |
May 16 2019, 08:19 PM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
betz |
May 17 2019, 10:03 AM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
I would go for the vto wheels But its a little hard to believe They fit narrow body car s read the listing with the proper offset add $30 ..@ 187 plus 30 ...makes them spendy for 914 wheels.. Or you can do their 16" ones already come with proper bolt pattern and offset. Would save around $60 a wheel, and the 16's look real nice imo. |
71six |
May 17 2019, 11:18 AM
I would go for the vto wheels But its a little hard to believe They fit narrow body car s read the listing with the proper offset add $30 ..@ 187 plus 30 ...makes them spendy for 914 wheels.. Or you can do their 16" ones already come with proper bolt pattern and offset. Would save around $60 a wheel, and the 16's look real nice imo. What are the chances of the VTO 7"x16" fitting a standard body (no rolled fenders) car? Assume 205 width tire at least, correct? (IMG:style_emoticons/default/idea.gif) |
betz |
May 17 2019, 02:57 PM
What are the chances of the VTO 7"x16" fitting a standard body (no rolled fenders) car? Assume 205 width tire at least, correct? (IMG:style_emoticons/default/idea.gif) Same as a 15x7 et35, except you will be running lower profile tires to keep the diameter the same. I think it's a tight fit from what I hear but should fit. Personally I'm not scared of rolling the fenders (rather than "pulling"), it just folds up the inside piece of metal and doesn't affect anything aesthetically. Worst comes worst you could just run 195's which wouldn't be a crazy difference. Disclaimer, I have not yet tried to run 205's et35 on a 914, so hopefully someone else can chime in on that fitment. |
Lo-Fi Version | Time is now: 29th March 2024 - 03:37 AM |
