running oil cooler lines to the engine now, Making my way back to the engine |
buck toenges |
May 15 2019, 05:24 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
I have decided to place my thermostat in the front trunk. I think it is easier for me to do that. I am routing the oil lines back to the engine compartment. Here are a few pics of my current set up on my 3.2. I could use some help plumbing the new oil lines back to the engine and oil tank. Can you tell me how to connect the new oil lines to the current oil lines please.
Here is the line from the bottom of engine to the oil tank. Here is the oil line from the tank. I am not sure where it goes. Here is another picture of this line that has the oil removal plug. I didn't picture the other oil line on top of the oil tank that I thinks goes to the cooler on the engine. So I am looking if I can use any of these lines in conjunction with the two oil lines coming back to the engine compartment on the drivers side. Thanks, Buck |
mb911 |
May 15 2019, 07:03 PM
914 Guru Group: Members Posts: 6,829 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Are you asking what line connects to the oil cooler???
If so basically you split the scavange line in half. One have connects to the front oil cooler and one half connects to the return portion that gets plumbed backed to scavange return into the tank. |
Lo-Fi Version | Time is now: 6th May 2024 - 08:16 PM |
