Dash Gauge Pod, Idea |
RolinkHaus |
May 15 2019, 05:35 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Looking to create an Audi style dash gauge pod. Has anyone tried this? Did a Google search with no luck. Not a fan of pillar mounted gauges. Probably going with Battery / Oil Temp / maybe a clock...or Cylinder Head Temp. VDO gauges, of course. (IMG:style_emoticons/default/piratenanner.gif)
Superhawk996 |
May 15 2019, 06:42 PM
914 Guru Group: Members Posts: 5,749 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I'll bite. Why? With ready availability of the center console that works and looks great I don't suspect you'll find what you're looking for for the 914 though you could certainly make one. Simple Path: You can make a custom face for console and fit many more than the stock 3 gauges (clock, oil temp, voltmeter). |
Superhawk996 |
May 15 2019, 06:43 PM
VaccaRabite |
May 15 2019, 07:05 PM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
There is a gauge plate that covers the stock radio location on the market that holds 3 two inch gauges. I have oil temp, head temp, and oil pressure there.
Clock and volt meter are on the A pillar in the pods. I don’t run the center console as my feet get stuck on it. I like the extra space without it. Zach |
malcolm2 |
May 15 2019, 07:26 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
VDO stopped making the CHT.... so if you're going for pretty, they won't match. I like the "deposit box" the 3 gauge thing wastes so much space. So I bought 2 VDO type 2 hole "L" brackets and put them under the dash and at the top of the deposit box. Very functional. A/F OT OP CHT
Superhawk996 |
May 15 2019, 07:27 PM
There is a gauge plate that covers the stock radio location on the market that holds 3 two inch gauges. I have oil temp, head temp, and oil pressure there. Clock and volt meter are on the A pillar in the pods. I don’t run the center console as my feet get stuck on it. I like the extra space without it. Zach I like it, but then what do you do for tunes. If you have a six then I understand . . . That is the best music! |
Porschef |
May 15 2019, 07:52 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
VDO stopped making the CHT.... so if you're going for pretty, they won't match. I like the "deposit box" the 3 gauge thing wastes so much space. So I bought 2 VDO type 2 hole "L" brackets and put them under the dash and at the top of the deposit box. Very functional. A/F OT OP CHT VDO probably stopped making their CHT because there’s a far better option out there. Zach, a simple reconstruction of the back of the center console opens up a world of extra room; I’m a size 11 and no longer have any issues with my foot getting stuck. That said, I like the look of the no console. But where would I put all the gauges? (IMG:style_emoticons/default/happy11.gif) |
bob164 |
May 16 2019, 12:58 AM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
A friend wanted to add three gauges that would be in his field of view, not down below the dash. He did the basic aluminum shape and I did the welding and wiring. It has VDO oil pressure, oil temp and voltage gauges and also a USB port. It appears to be mounted a little low, but when in the driver's seat you can see the entire range of each gauge.
And yes, he has a sense of humor. |
RolinkHaus |
May 16 2019, 02:20 AM
RolinkHaus |
May 16 2019, 02:35 AM
Love the Vitaloni Sebring mirrors, but in order to see behind, placement is key. Still experimenting.
VaccaRabite |
May 16 2019, 07:46 AM
I like it, but then what do you do for tunes. If you have a six then I understand . . . That is the best music! 70 watt amp hidden under the dash, with a hardwired minijack run to the center armrest compartment that I can plug my iphone into. Easy! Volume control is all done through the iPhone. At least that was what I did until I pulled it all out when I realized I wasn't using it. I tend not to listen to music in my 914. Zach |
campbellcj |
May 16 2019, 09:18 AM
I can't Re Member Group: Members Posts: 4,540 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
FWIW I ran the 3-gauge VDO radio slot setup for a few years and it did look nice and function fine, but I found it undesirable to divert attention to look at them. I went to the quad-gauge in the standard dash location; a triple gauge would've been fine/better in hindsight. (Voltmeter is pretty useless.)
jrblackbox |
May 16 2019, 09:25 AM
Member Group: Members Posts: 285 Joined: 8-September 15 From: Easton, CT Member No.: 19,140 Region Association: None |
There is a gauge plate that covers the stock radio location on the market that holds 3 two inch gauges. I have oil temp, head temp, and oil pressure there. Clock and volt meter are on the A pillar in the pods. I don’t run the center console as my feet get stuck on it. I like the extra space without it. Zach I want to rid myself of the center console too. Where can I find this gauge plate that covers the radio location? |
dr914@autoatlanta.com |
May 16 2019, 09:29 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
reminds me of the old amco console, Jeff bowlesby may have a picture of one installed. Has an armrest and a guage pod that sort of looks like the Audi pictured
Looking to create an Audi style dash gauge pod. Has anyone tried this? Did a Google search with no luck. Not a fan of pillar mounted gauges. Probably going with Battery / Oil Temp / maybe a clock...or Cylinder Head Temp. VDO gauges, of course. (IMG:style_emoticons/default/piratenanner.gif) |
malcolm2 |
May 16 2019, 09:48 AM
Not installed, but you get the idea. I would love to find one of these.... I have 4 gauges tho. Don't remember seeing one with the rectangle gadget with the LCD. Wonder what that is. Plus are the rocker switches usually used for seat heaters or power windows?
thelogo |
May 16 2019, 09:55 AM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Cant remember who has it
But id toss all those guages and just get the Fuel guage that has a huge red oil light. Size of entire guage i think Do you really need more then that . |
7TPorsh |
May 16 2019, 10:45 AM
7TPorsh |
dupe post
malcolm2 |
May 16 2019, 10:56 AM
Cant remember who has it But id toss all those gauges and just get the Fuel gauge that has a huge red oil light. Size of entire gauge i think Do you really need more then that . CHT and OT has caused me to check around. A full size paper towel had been sucked into the fan and was covering 1/3 or 1/2 of the fins. OT went up to 260 on a 80* day. I knew something was wrong. CHT needle does not move as far for a 20* increase, but I noticed a change. another time, my ALT light came on on a 3 hour interstate trip. The voltage gauge assisted in how close I could get to home before shutting it down..... 8.5 volts as I pulled into a Cracker Barrel parking place.... 45 minutes from home. For some people they are nice to have, some look nice, and I enjoy the feedback. To each his own.... like brands of oil, tires, etc.... |
VaccaRabite |
May 16 2019, 11:05 AM
I want to rid myself of the center console too. Where can I find this gauge plate that covers the radio location? I got mine a few years back from RennMetal ( I think). But its just a flat sheet of steel with three 2 1/16th inch holes in it. You could make one yourself in just a few minutes with a 2 inch hole saw and some 18 or 16 ga stock steel from your local hardware store. Super simple design. Zach |
Lo-Fi Version | Time is now: 26th April 2024 - 07:03 PM |
