Dash Gauge Pod, Idea |
RolinkHaus |
May 15 2019, 05:35 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
Looking to create an Audi style dash gauge pod. Has anyone tried this? Did a Google search with no luck. Not a fan of pillar mounted gauges. Probably going with Battery / Oil Temp / maybe a clock...or Cylinder Head Temp. VDO gauges, of course. (IMG:style_emoticons/default/piratenanner.gif)
VaccaRabite |
May 15 2019, 07:05 PM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
There is a gauge plate that covers the stock radio location on the market that holds 3 two inch gauges. I have oil temp, head temp, and oil pressure there.
Clock and volt meter are on the A pillar in the pods. I don’t run the center console as my feet get stuck on it. I like the extra space without it. Zach |
Superhawk996 |
May 15 2019, 07:27 PM
914 Guru Group: Members Posts: 5,777 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
There is a gauge plate that covers the stock radio location on the market that holds 3 two inch gauges. I have oil temp, head temp, and oil pressure there. Clock and volt meter are on the A pillar in the pods. I don’t run the center console as my feet get stuck on it. I like the extra space without it. Zach I like it, but then what do you do for tunes. If you have a six then I understand . . . That is the best music! |
VaccaRabite |
May 16 2019, 07:46 AM
I like it, but then what do you do for tunes. If you have a six then I understand . . . That is the best music! 70 watt amp hidden under the dash, with a hardwired minijack run to the center armrest compartment that I can plug my iphone into. Easy! Volume control is all done through the iPhone. At least that was what I did until I pulled it all out when I realized I wasn't using it. I tend not to listen to music in my 914. Zach |
Lo-Fi Version | Time is now: 3rd May 2024 - 11:53 PM |
