SEALS - Different that orig, WAS: OIL: Flood, Leak and Seeps, Will they work ? |
ctc911ctc |
May 20 2019, 03:16 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
Please see the seal picture around post #9
All, I had all three, Floods, Leaks and Seeps. I fixed the Flood, yes the valve cover HAS to go on with the VW logo upside down! So on to the leaks. I am down to one leak, the oils is dripping off of the oil filter, a drop a minute or two while running. This leak is NOT coming from the top of the engine. Oil pressure sending unit, oil filler (OEL)and the distributor are all tight, no leaks. Took out the oil filter, let the car leak until it stopped dripping and got under the car. OK, I spent an hour under the car. Pretty certain that the car is leaking from ABOVE the oil filter mounting bracket. Top of the braket and the bottom part of the oil cooler are covered in oil. Sooooo, after reading everything about this within these pages I found that the oil filter bracket AND the oil cooler could be removed WITHOUT removing the engine. GREAT! So raised the car high, put it on jackstands AND 4x4 blocks (belt and suspenders) and slid underneath. took the first nut off the oil filter mount, then I went for the one on the back of the bracket. A - Easy Bracket nut B - Nut on top of bracket - seen through a mirror C - Oil Pressure regulator Access Port D - Above the Oil Cleaner bracket - covered with oil. As can be seen, the nut for the other half of the mount is overlapped by the oil cooler frame. THERE IS NO WAY TO GET A WRENCH ON THIS! Not sure what to do now, live with the leak until it is time to remove the engine? Ideas, suggestions, Many thanks in advance. BTW, the seeps are all from the pushrod tubes, only one looks really bad, not sure I would venture to pull the tubes with the engine in the car, though I know it can be done. |
Superhawk996 |
May 24 2019, 03:57 AM
914 Guru Group: Members Posts: 5,812 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Alright I'll be the jackass. . . . just drop the engine. Working on a 914 engine is like racing. Sometimes you just have to go slow in a particular corner to get a good lap time. It seems like the hour or so to drop the engine is wasted time. It's not. I know it seems like a pain to pull an engine but it is the fastest, least stressful way to do most of the work on a 914 engine. Plus, then you get easy access to . . . and can see other things that you might not have been able to see laying under it. |
ctc911ctc |
May 24 2019, 07:17 AM
(IMG:style_emoticons/default/confused24.gif) Alright I'll be the jackass. . . . just drop the engine. Working on a 914 engine is like racing. Sometimes you just have to go slow in a particular corner to get a good lap time. It seems like the hour or so to drop the engine is wasted time. It's not. I know it seems like a pain to pull an engine but it is the fastest, least stressful way to do most of the work on a 914 engine. Plus, then you get easy access to . . . and can see other things that you might not have been able to see laying under it. Got it, Drop Engine. I plan on doing this in the fall, right now I do not have the tools or the space to do it "properly" - totally get the notion though. Will try one more time with bearing grease as the secret weapon. |
Lo-Fi Version | Time is now: 14th May 2024 - 03:22 AM |
