Another Front Oil Cooler, 76 914 Now Running Much Cooler |
pvollma |
May 20 2019, 06:04 PM
Member Group: Members Posts: 205 Joined: 12-May 13 From: Camp Hill, PA Member No.: 15,862 Region Association: MidAtlantic Region |
I bought my 76 in 2013, and it always ran way too hot in the summer. Cruising at highway speeds would show close to 240, and getting stuck in traffic could get that up to 250. Since it is definitely a fun car, I wasn't too concerned since I could avoid the most trying of drives, but I knew I had to do something eventually.
I once had a 72 914 2.0 that I ran in SCCA GT-3 racing in S. Texas, and the easy solution was to put a small oil cooler in series in each front wheel well, with the turn signals removed for track use to allow great airflow across the coolers. This kept the oil temps down to 200-210, even in the August heat at Texas World Speedway. For a street car, the turn signal trick obviously wouldn't work. Tony at Translog (York, PA) had found a different solution for his race car, by accessing a walled-off area of the front trunk under the headlights: This seemed like an interesting solution, as the cooler is protected, and air could be ducted to it if necessary. Unlike a lot of the front cooler solutions, this did not involve cutting into the usable trunk space and providing for both an inlet and outlet for the airflow. So, I decided to let him do the same with mine (with just one cooler in the front passenger-side wheel-well - Tony uses two coolers for the race car). The result is something that is working really well for my stock setup: Today was one of the first this year with ambient temps in the mid to upper 80's, so I took it for a drive, about 10 miles at 70, then another 5-6 at 45, then stop and go for about 4 miles, then back up to 65 for a few miles until getting back to my garage. The max oil temperature while on the highway was about 190, when I got into the stop and go it went up to near 210, then back to about 200 by the time I got home. Before adding the cooler, I would have been well over 210 on the highway, and gotten up to 240 or more in stop and go traffic. I have seen as high as 260 when stuck in traffic for an extended period, which I believe is the stated factory maximum. Needless to say, I'm very pleased with the results. For colder weather driving, I plan to look into a second thermostat to control oil flow to the front cooler. |
SirAndy |
May 20 2019, 07:34 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Now the real question is, why is your engine running so hot?
(IMG:style_emoticons/default/confused24.gif) |
Superhawk996 |
May 20 2019, 07:38 PM
914 Guru Group: Members Posts: 5,765 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
That's what I was wondering especially if OP is in PA. Big bore? Bad engine seals? Or was it "fixed" by removing the cooling flaps? |
pvollma |
May 20 2019, 07:58 PM
(IMG:style_emoticons/default/agree.gif) That's what I was wondering especially if OP is in PA. Big bore? Bad engine seals? Or was it "fixed" by removing the cooling flaps? The engine is stock, everything cooling-related is there and appears to be working, 97,000 miles. Oil pressure is now the preferred 10 psi/1000 RPM. Prior to adding the cooler, I would always get the flickering oil pressure light at idle when the engine was hot. In my write-up, I mentioned the extreme times when the oil temp concerned me, such as spirited driving in our hilly and twisting terrain. I see I said that it "always ran too hot in the summer" but that's mostly because when I bought the car it had the stock oil temp gauge and it would normally run near the top of the white area, but stay several needle widths away from the red. Most cars I've driven run with the temp gauge near the middle of the range. |
Carl La Fong |
May 20 2019, 09:16 PM
Member Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None |
Is your oil temp. sender and gauge accurate? Do you trust that it is?
type2man |
May 20 2019, 11:34 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
The oil light flickering after a few miles usually indicates excess wear in the bearings, or perhaps a low viscosity oil. Adding the cooler is a band aid. I am not a big fan of gauges other than the oil and gen lights. They just make me more nervous. I have an infrared thermometer gauge that I take with me once in a while and check temps once I stop after a long drive. South florida is about as hot as it gets...
Superhawk996 |
May 21 2019, 05:14 AM
The oil light flickering after a few miles usually indicates excess wear in the bearings, or perhaps a low viscosity oil. Adding the cooler is a band aid. I am not a big fan of gauges other than the oil and gen lights. They just make me more nervous. I have an infrared thermometer gauge that I take with me once in a while and check temps once I stop after a long drive. South florida is about as hot as it gets... (IMG:style_emoticons/default/agree.gif) My original 914 just started flickering one day at idle - for apparently no reason. One day it was fine, the next day it wasn't. Time for rebuild. When torn down bearings were worn. Crank was fine. If you're getting flickering at idle with stock set up --REBUILD before you have a catastrophic failure like spun bearings, tear up the crank, and shrapnel the inside of the engine with debris. As stated oil coolers are likely a band-aid. The other thing is - be sure you aren't lugging it, especially on hills. Rev's are your friend on air cooled to get that fan moving air and to get the oil pump pumping more oil. These engines are called air cooled but they depend equally as much on oil cooling and the oil pump has to be pumping oil to do that. The other thing is the stock gauge red zone starts at something like 160F if I recall (don't quote me on this - please look it up) and there were two version that had slightly different red zones. So if I recall correctly, running on edge of Red shouldn't be alarming. Not all gauges run at mid point. Well at least my Tach and fuel gauge don't. (IMG:style_emoticons/default/lol-2.gif) I drove my original (after rebuild) at high speeds in FL with hot temps - no overheating as stated above. |
SirAndy |
May 21 2019, 10:57 AM
... there were two version that had slightly different red zones ... If i recall correctly, Porsche changed to a different gauge with a smaller red zone after too many people complained about their cars running hot. (IMG:style_emoticons/default/biggrin.gif) |
brant |
May 21 2019, 11:01 AM
914 Wizard Group: Members Posts: 11,616 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
cutting the front corners out would concern me for unit body strength
was any bracing added back to replace the strength? the front torsion bar mounts don't have a lot of metal in the front trunk to reinforce them. I added a brace bar between the 2 mounts out of concern on my car. brant |
Spoke |
May 21 2019, 11:38 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The installation looks really clean. Nice job.
saigon71 |
May 21 2019, 06:45 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
The installation looks really clean. Nice job. (IMG:style_emoticons/default/agree.gif) Hard to go wrong with running cooler. (IMG:style_emoticons/default/beerchug.gif) |
thelogo |
May 21 2019, 06:56 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Funny how you speak of temp swing of
30/50 deg .on a guage with no numbers Or vague numbers . I actually like the wheel well oil cooler More race style imo But im not a mechanic and my big /4 Has a external cooler under the rear trunk ( cruise night style) No gauge just stock oil light But fan kicks on when things get hot (IMG:style_emoticons/default/wub.gif) What oil you running btw ? |
Spoke |
May 21 2019, 08:28 PM
But fan kicks on when things get hot A fan is a good addition to keep things cool. I just put a fan on the wheel well oil cooler of my 930. It makes a world of difference with keeping the oil temps lower. When the engine is warm and the fan is on, the amount of heat being removed is amazing. The wheel well oil cooler in the 911 couldn't have been put in a more remote location wrt airflow. The horns are in the way on the bottom side and the headlight bucket almost completely blocks the top part of the cooler where the fan is not. |
pvollma |
May 21 2019, 10:12 PM
Funny how you speak of temp swing of 30/50 deg .on a guage with no numbers Or vague numbers . What oil you running btw ? The car had the stock oil temp gauge in the center console when I bought it. I replaced that a few years ago with a VDO 120-300 degree gauge. Oil is Swepco 15w-40, but I've tried other brands and weights with similar results. |
pvollma |
May 21 2019, 10:14 PM
cutting the front corners out would concern me for unit body strength was any bracing added back to replace the strength? brant The corner was cut, reshaped to accommodate the cooler, and then re-welded in the new configuration, so I suspect there was minimal change in strength. |
pvollma |
May 21 2019, 10:32 PM
We had the car up in the air today and I discovered that there is actually an unintended air inlet for the cooler:
I am assuming that is a stock opening in the 76 front bumper. |
Lo-Fi Version | Time is now: 29th April 2024 - 11:43 PM |
