What's this tool for, I can't remember why I bought this |
Highland |
May 21 2019, 06:10 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I bought this as part of a GB on this site thinking some day I'd be glad I had it if I ever did front suspension work.
I just finished taking everything apart except for the steering rack and tie rods. Is that what its for; if so what application? |
toolguy |
May 21 2019, 06:24 PM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
the spanner end look like the ball joint retainer. the wrench may fit the tie rods
jim_hoyland |
May 22 2019, 05:22 AM
Get that VIN ? Group: Members Posts: 9,263 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I have one too; so far I’ve loaned it out 3x....
Luke M |
May 22 2019, 05:45 AM
Senior Member Group: Members Posts: 1,369 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I bought this as part of a GB on this site thinking some day I'd be glad I had it if I ever did front suspension work. I just finished taking everything apart except for the steering rack and tie rods. Is that what its for; if so what application? It's a inner tie rod tool. One end if for the factory rod end the other which should be 32 mm is for the turbo tie rods. |
Highland |
May 28 2019, 02:34 PM
Ok. so I guess I should have removed the boot to see that the washer is notched for the tool as I discovered today.
So I worked on both tie rod ends today and couldn't get either one loose. Will I break something in the steering rack if I turn too hard? Any suggestion on how to get the tie rod ends loose from the steering rack? Steering rack is still in the car. In difficult situations like this is it advised to remove the rack? I assume its a right hand thread. |
Lo-Fi Version | Time is now: 27th April 2024 - 03:02 PM |
