CV joint axles pulled, Lots of hub play |
shane |
May 21 2019, 07:47 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
I was unaware of the set up and without thinking pulled my CV joints to replace them the whole time with the car not on jack stands. I rolled it in and out of my garage also a few times and now there is a good amount of play. Do I even try to put it all back together and tighten the castle nut? Or is the bearings in the hub messed up for sure?
SirAndy |
May 21 2019, 07:55 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you just rolled it around the garage, you should be fine.
Put the axle back in and tighten up the nut and see if you still have play. Make sure you check both the 9-3 o'clock as well as the 12-6 o'clock plane for play. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:36 AM |
