Turn signal reinstall, Doesn’t fit |
Wew |
May 22 2019, 07:55 PM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
Installing new switches into steering column and also did the electric motor pump washer upgrade. I am having a heck of a time getting both of the windshield wiper and turn signal wire housings to fit back through the steering column channel. There has to be something I am doing wrong. Anyone with any experience doing this, your feedback and help is much appreciated. Thank you, Gary |
worn |
May 22 2019, 09:53 PM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi all, Installing new switches into steering column and also did the electric motor pump washer upgrade. I am having a heck of a time getting both of the windshield wiper and turn signal wire housings to fit back through the steering column channel. There has to be something I am doing wrong. Anyone with any experience doing this, your feedback and help is much appreciated. Thank you, Gary Nice photo. As I recall the wires can be hard to stuff into place. Where did you get the switches from? |
JeffBowlsby |
May 22 2019, 10:04 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
That’s the bottom view, it’s up side down. Did you know that?
jcd914 |
May 22 2019, 10:22 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The new wiper switch you are using has the electrical contacts for the washer pump and so it has a different wire guide for the extra wires. It is too wide to fit in the steering column.
The plastic wire guide from the old wiper switch has to be transferred to the new wiper switch. You end up with the wires in the same slots. Jim |
worn |
May 23 2019, 02:43 AM
The new wiper switch you are using has the electrical contacts for the washer pump and so it has a different wire guide for the extra wires. It is too wide to fit in the steering column. The plastic wire guide from the old wiper switch has to be transferred to the new wiper switch. You end up with the wires in the same slots. Jim I haven’t done this for a few years but I seem to remember that you end up with the washer pump wires not fitting the old plastic loom and having to go through loose. Not too easily either. The pump wires also need separate connections to non original wires that one runs to the pump. |
dr914@autoatlanta.com |
May 23 2019, 08:10 AM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
you will have to use the wire channel from your old switch and stagger the extra wire on top. A direct fit on the 75 76 models however but not on the 72-74
Wew |
May 23 2019, 08:37 AM
you will have to use the wire channel from your old switch and stagger the extra wire on top. A direct fit on the 75 76 models however but not on the 72-74 Hi all, Thanks much for the input. Much appreciated. (IMG:style_emoticons/default/pray.gif) |
Bleyseng |
May 23 2019, 10:29 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
which switch did you use?
seanpaulmc |
May 23 2019, 11:04 AM
Member Group: Members Posts: 297 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
Please post a similar picture with the old wire loom in place before you reinstall. Thanks!
Lo-Fi Version | Time is now: 25th April 2024 - 01:56 PM |
