Rear sway bar yes or no?, 22mm hollow RSR Style Tarett sway bar front, rear sway bar needed or not? |
CG-914 |
May 25 2019, 08:16 AM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi 914 suspension wizards,
I do club racing with the POC in CA on the tight handling courses so far (IMG:style_emoticons/default/piratenanner.gif) . I'm about to install a front Tarett 22mm hollow RSR style sway bar. Rear sway bar yes or no? I do still drive the car on the street as well.... The car has Toyo R888, 140lbs springs so far, but it eventually is going to a 6 with 22mm torsion bars in the front and adjustable 300lbs springs in the rear and of course a 5 lug conversion. Thanks |
campbellcj |
May 27 2019, 07:51 AM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have a similar race setup, a bit stiffer though - 22 hollow tbars, SRP swaybar (#27 I think), 350lb rears w/ factory swaybar.
Lo-Fi Version | Time is now: 16th May 2024 - 11:25 PM |
