Rear sway bar yes or no?, 22mm hollow RSR Style Tarett sway bar front, rear sway bar needed or not? |
CG-914 |
May 25 2019, 08:16 AM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi 914 suspension wizards,
I do club racing with the POC in CA on the tight handling courses so far (IMG:style_emoticons/default/piratenanner.gif) . I'm about to install a front Tarett 22mm hollow RSR style sway bar. Rear sway bar yes or no? I do still drive the car on the street as well.... The car has Toyo R888, 140lbs springs so far, but it eventually is going to a 6 with 22mm torsion bars in the front and adjustable 300lbs springs in the rear and of course a 5 lug conversion. Thanks |
mepstein |
May 25 2019, 11:47 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Like the previous poster said, from the research I’ve done, it’s either really heavy springs and no bar or lighter springs with a bar.
ConeDodger |
Jun 29 2019, 07:24 PM
Apex killer! Group: Members Posts: 23,588 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Like the previous poster said, from the research I’ve done, it’s either really heavy springs and no bar or lighter springs with a bar. (IMG:style_emoticons/default/agree.gif) I use 200# rear springs and a bar on tight courses and disconnect one end of the bar on wide open courses. I use the same front bar as you will be using. There is no rubber in my suspension at all and I cornerbalance yearly. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:02 PM |
