Rear sway bar yes or no?, 22mm hollow RSR Style Tarett sway bar front, rear sway bar needed or not? |
CG-914 |
May 25 2019, 08:16 AM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi 914 suspension wizards,
I do club racing with the POC in CA on the tight handling courses so far (IMG:style_emoticons/default/piratenanner.gif) . I'm about to install a front Tarett 22mm hollow RSR style sway bar. Rear sway bar yes or no? I do still drive the car on the street as well.... The car has Toyo R888, 140lbs springs so far, but it eventually is going to a 6 with 22mm torsion bars in the front and adjustable 300lbs springs in the rear and of course a 5 lug conversion. Thanks |
Justinp71 |
Jul 3 2019, 10:26 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Not to derail too much but for those of you running high spring rates (250+) in the rear, do you have the GT re-enforcement kit? I was once told high spring rates will tear apart the rear shock towers if not re-enforced. Seems like a rear sway bar with softer springs could be easier on the chassis for those of us with no rear re-enforcement.
Lo-Fi Version | Time is now: 16th May 2024 - 07:50 PM |
