Rear sway bar yes or no?, 22mm hollow RSR Style Tarett sway bar front, rear sway bar needed or not? |
CG-914 |
May 25 2019, 08:16 AM
Member Group: Members Posts: 323 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
Hi 914 suspension wizards,
I do club racing with the POC in CA on the tight handling courses so far (IMG:style_emoticons/default/piratenanner.gif) . I'm about to install a front Tarett 22mm hollow RSR style sway bar. Rear sway bar yes or no? I do still drive the car on the street as well.... The car has Toyo R888, 140lbs springs so far, but it eventually is going to a 6 with 22mm torsion bars in the front and adjustable 300lbs springs in the rear and of course a 5 lug conversion. Thanks |
ottox914 |
Jul 10 2019, 12:25 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I also would have a factory rear sway bar for sale. The bushings in the drop links are dried out and junk. I do not have the special bolts to go into the trailing arms to connect the bar to. They were to badly rusted into the parts car to get them out. So the parts I have are a little bit of a project before they can be installed.
PM me if interested. Thx- |
Lo-Fi Version | Time is now: 16th May 2024 - 09:24 PM |
