What's the easiest oil catch can for a 6? |
patssle |
May 25 2019, 12:53 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Besides a Gatorade bottle! That's what I currently have on my 914-6. I'd like to put a real catch can with the air filter - has anybody found a good option that works on our cars. Either with it in the engine bay or the rear trunk.
campbellcj |
May 25 2019, 02:11 PM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have a Canton aluminum one in the rear trunk near the left shock tower. It prevents using the stock targa top holders or jack holder, however. My car has those removed.
Dion |
May 25 2019, 02:19 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
The factory used the washer bottle from 356’s I believe. For the GT’s that is.
Along the lines of this... Maybe as a starting point. They mounted them in the trunk. Attached thumbnail(s) |
Mark Henry |
May 25 2019, 02:34 PM
This is my design, I'd like to sell them but I haven't had the time with all the 996 engines I've been building. Two more cars arrived this last week, a 997 C4S and a 996 targa.
Pete at RD said he will laser cut the parts for me, but I need to see if I can do something to refine the design and reduce the amount of welding needed. http://www.914world.com/bbs2/index.php?sho...p;#entry2496535 (IMG:http://www.914world.com/bbs2/uploads/post-26-1497373923_thumb.jpg) |
cary |
May 25 2019, 02:45 PM
Mark, thats a great looking piece. Exactly where it needs go.
worn |
May 25 2019, 03:19 PM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Mark, thats a great looking piece. Exactly where it needs go. Would’ve saved the planet from a quart of oil returning from WCR last year. My solution came from a critical search of eBay. Key word meaning to be sure it was what you want prior to ordering, not doing which the first time led to aforesaid oil leaking upon the planet. I know we are always counting on the Canadian s Mark, but maybe you will help us out here. |
horizontally-opposed |
May 25 2019, 04:09 PM
Advanced Member Group: Members Posts: 3,430 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Mark, thats a great looking piece. Exactly where it needs go. +1 Really nice looking piece, and nicely thought out, too. Very pretty in aluminum...does it need to be? Would some sort of high-grade plastic (or?) work in that location? Or does heat make that a nonstarter? Just thinking out loud. |
rgalla9146 |
May 25 2019, 05:03 PM
Gatorade bottle ? no way!
Seltzer bottle is the only way to go. Two zip ties, (or one for weight saving) leave 6 oil tank breather hose stock length. No drilling. Not visible unless you look. Cut five or six slits along the top surface of the bottle. Stock hose clamp to secure hose to bottle neck. Slip an old sock over bottle in lieu of a silly K&N filter. Glenn Stazak approved. Attached thumbnail(s) |
rgalla9146 |
May 25 2019, 05:11 PM
other view
Steve |
May 25 2019, 05:58 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
campbellcj |
May 25 2019, 06:18 PM
That PMS one looks virtually identical to the Canton I have, from Pegasus I think.
Mark Henry |
May 26 2019, 05:47 AM
Mark, thats a great looking piece. Exactly where it needs go. +1 Really nice looking piece, and nicely thought out, too. Very pretty in aluminum...does it need to be? Would some sort of high-grade plastic (or?) work in that location? Or does heat make that a nonstarter? Just thinking out loud. I don't know how to make it out of plastic, likely would take a mould/die of some kind that would be a big tooling cost, plus it's more than just a can as it has a baffle inside and is correctly vented. The one in the pic actually didn't work out, I ended up cutting and rewelding it 3-4 times before I got it right. It's fully functional with breather hoses to the air cleaner rainhats and the big hose to the engine case, with a petcock to drain the tank. The problem is to find the time (IMG:style_emoticons/default/rolleyes.gif) . |
May 26 2019, 10:08 AM
Resident German Group: Admin Posts: 41,609 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Besides a Gatorade bottle! What's wrong with a Gatorade bottle? (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1255294222.jpg) |
patssle |
May 26 2019, 11:37 AM
These other options are expensive! I'm liking my Gatorade bottle more and more. (IMG:style_emoticons/default/biggrin.gif)
PanelBilly |
May 26 2019, 12:03 PM
914 Guru Group: Members Posts: 5,799 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I got one from Amazon and mounted it in the corner in front of the oil tank filler neck. It has a drain tube that runs out under the car. I’ll post a photo later.
914 Ranch |
May 27 2019, 01:11 AM
Team Sharp where the 914 grow wings Group: Members Posts: 1,410 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States |
I don't drink Gatoraide. Carerror only drinks Castrol HD 30.
Easy install and vents at the top. She has a set of bad rings and can fill the muffler with oil if left with the front end jacked for extened periods of time but after a year of auto crossing the bottle was only half full. |
rgalla9146 |
May 27 2019, 06:31 AM
Besides a Gatorade bottle! What's wrong with a Gatorade bottle? (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1255294222.jpg) My comment about Gatoraid/seltzer bottles is a poke at elaborate installations. A vented clear plastic bottle is a simple, easy, no cost, no drilling solution to capture crankcase blowby/vapors when the stock 6 air filter is removed. It's practically invisible and allows easy view of accumulation. |
Lo-Fi Version | Time is now: 1st May 2024 - 03:48 PM |
