FS: Misc. Cooling Tins Shrouds Plenums Oil Fill Air Guides |
carl k |
May 25 2019, 03:28 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Selling a bunch of misc. sheet metal parts. All prices plus shipping (or pick up in San Jose, CA).
under cylinder baffle tins: $15 a matched pair, or $5 for the single one rear engine cover plate (has some dents): $5 cylinder front and rear tins: $5 each, $5 for the rubber oil cooler gasket, or $20 for a complete set of four with rubber. early 1.7L cylinder rear tin with heat riser: $7 oil fill pedestal includes funnel, bail clip and PCV valve: $15 1.7L intake plenum: $10 assorted under heat exchanger air guides: $7 each left front engine tin (under alternator): $5 center tunnel cover plate at pedal assy: $5 left side 1.7/1.8 cylinder top tin: $10 Some parts may have issues such as splits, bends, or torn-out mounting holes. Let me know what you're interested in and I can pick the best ones and send detailed pics, or make price adjustments. thanks! Carl |
Lo-Fi Version | Time is now: 5th May 2024 - 02:14 AM |
