Triad West has carb linkage too, Recent Pictures |
Triaddave |
Jun 4 2019, 11:03 AM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
This new batch of linkage has a great up-grade. The thumb screw for the up-down adjustment is now billet made, all one piece with right and left threads. As always, all hard parts are powder coated Black. The hines joints are also r/l threads for ease of adjustment. Aluminum plate is laser cut onder oil for clean cuts and accuracy.
In stock and available at $245.00 each. 360 280-6855 |
rhodyguy |
Jun 4 2019, 02:17 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
You got my message? FWIW, these are great linkages. 100% better than most of the other offerings. With the use of bolts and lock nuts on the crossbar ends, NOT spring loaded, the setup stays very consistent and smooth thru out the range of motion. Very straight forward to set up.
Triaddave |
Jun 6 2019, 10:36 AM
I forgot to mention, All weld are tig and beautiful.
Lo-Fi Version | Time is now: 29th April 2024 - 05:05 AM |
