FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,964 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I had a new key cut and it seems that it's juuuust a bit "off" - it works fine in one orientation (both in the doors and in the ignition) but if you flip it over, it won't turn - easily, anyway. You can wiggle it around and gently put a little pull on it and it MIGHT turn.
I had a door lock cylinder out at the time and noticed that it doesn't quite suck in the wafers to the point where they are flush with the cylinder. Does this mean the key was cut too far/deep or not far enough? I'm wondering if a little gentle overall filing/smoothing might help but not sure which side to do since it turns one way, but not the other... |
Lo-Fi Version | Time is now: 4th July 2025 - 09:00 AM |
