non start issue--solved the problem, replaced the ignition switch, now loud buzz |
cooper951 |
Jun 8 2019, 06:06 AM
Member Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
cooper951 |
Jun 8 2019, 01:17 PM
Look for a stray small brown wire. It should attach directly to the chassis. Thanks. Any idea on location? Cabin? Engine compartment. I cleaned things up a bit, and found a small brown wire with a yellow stripe. I also found a small connector clip, and some other wires at the bottom of the pic that aren't attached to anything, plus some sets with push on plastic connectors, which were also unconnected. Is that small brown wire the one you were talking about. I can't find anywhere that it should connect to. Once again both pics should be rotated 90 degrees to the right. Sorry. Attached image(s) |
AvalonFal |
Jun 8 2019, 02:54 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
This is the brown ground wire on my '74 2.0. It attaches to the body. When I disconnect, engine cranks but no start.
Paul |
cooper951 |
Jun 8 2019, 03:01 PM
This is the brown ground wire on my '74 2.0. It attaches to the body. When I disconnect, engine cranks but no start. Paul Thanks for the visual. Where does the other end of the brown wire attach to? Mine won't crank at all. You can hear the fuel pump, but nothing at all from the starter. |
cooper951 |
Jun 12 2019, 05:12 PM
A bit embarrassed to admit it, but I installed a Bosch Hot Start Kit a few years back, and I thought that something might be malfunctioning on it. There is an inline fuse on it, the fuse was blown. Switched out the fuse, and it started right up. Don't know why it happened, but will keep tabs on it. At least she is running again.
Lo-Fi Version | Time is now: 1st June 2024 - 11:23 AM |
