1968 Volkswagen Baja Bug with Raby balanced 2270 |
tomeric914 |
Jun 6 2019, 10:17 AM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
2270 Jake Raby balanced Type 4 engine 78.4mm DPR counterweighted crankshaft 96mm Keith Black pistons 96mm AA Cylinders CB Performance Super Race 5.4” H-beam rods WebCam 163/86b camshaft Manton steel pushrods Real 911 swivel feet adjusters Mark Stephens ported and polished heads Dual Weber IDF40 with 36mm venturis Raby DTM fan shroud Mallory Unilite vacuum advance distributor MSD Ignition Remote full flow oil filter All oil galleys threaded and plugged Holley red fuel pump Fuel pump interlock relay Custom A-1 header and Magnaflow muffler all Jet-Hot ceramic coated Dave Folts close ratio gearbox Custom electronic speedometer pickup Welded 1st and 2nd Close ratio 3rd and 4th SuperDiff with 4 gears 4.12 ring and pinion Interior Beard custom high back suspension seats (front) Seats mounted to 1-1/2” body lift tied into the center tunnel No seats in the rear (carpeted) Bugpack short throw T-shifter VDO and Westach gauges VDO electronic speedometer Porsche 914 Tachometer Pioneer cassette deck (lol) with 6x9 Pioneer speakers mounted in the rear deck Second Skin sound deadening coating on the floors Second Skin Damplifier and Luxury Liner on the firewall and rear seat area Exterior 1-1/2” body lift tied into the center tunnel Centerline polished 5-bolt wheels (15x8 rear, 15x6 front) Bridgestone AT Revos (31x10.5x15LT rear, 215/75R15 front) Narrow eye fiberglass Baja kit Quick-latch locking hood pins Bugpack rear race fenders One-piece windows ATL 12-gallon fuel cell Tubular bumpers Suspension/Brakes Thing front suspension ’74 IRS rear suspension Koni adjustable steering damper Bilstein shocks BMW 318i master cylinder CSP front disc brakes Type 3 rear drums My first car which I’ve owned, maintained and refined for 34 years. As an Engineer, I have carefully thought out each and every modification to the nth degree. I’ve only put about 100 miles on it per year for the past 10 years so I think it’s time to let someone else enjoy it. Only about 4000 total miles on the engine and transmission and most of the vehicle since I went through it about 18 years ago. Rear brakes were just redone this Spring with all new hardware, POR-15’d drums and proper pressed in 14mm studs. Paint job isn’t the greatest but still looks darn good driving down the road. Always stored inside in a climate-controlled garage and never driven in winter. $14k obo Pictures below... |
tomeric914 |
Jun 6 2019, 08:40 PM
Lo-Fi Version | Time is now: 28th April 2024 - 08:36 PM |
