Genuine Minilite 15X6.5 lugbolts pics please, verification purposes |
Abeck914 |
Jun 11 2019, 08:36 AM
Newbie Group: Members Posts: 25 Joined: 4-December 17 From: Rhode Island Member No.: 21,677 Region Association: None |
Could someone please post a pic of the correct lugbolt for the 15X6.5 Genuine Minilite.
I believe they should be M14, 9mm diameter, 44mm thread length, with a continuous diameter smooth shank [not beveled/conical/ball]? or would appreciate corrections if I'm wrong. - thank you, Aaron |
sixnotfour |
Jun 13 2019, 12:22 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
well someones been doing something to em..bummer, first holes look like tapered seat inserts, the one hole looks flat and not concentric to the insert..is that correct ??
fyi, wobble bolts only work for hub centric wheels.. |
Abeck914 |
Jun 13 2019, 02:04 PM
well someones been doing something to em..bummer, first holes look like tapered seat inserts, the one hole looks flat and not concentric to the insert..is that correct ?? fyi, wobble bolts only work for hub centric wheels.. well someones been doing something to em - deciphering just what is what this exercise has been all about (IMG:style_emoticons/default/av-943.gif) I think what we see in the pic is one hole with a tapered insert, as exists in all holes. Then the pic with the bolt, has the conical washer removed [as some do, and other bolts are fixed conical shape under bolt head] from the bolt and sitting in one of the tapered inserts. I think I will know the next step when the original style bolt arrives. but i'm nervous to remove inserts because I don't know how much the original diameter of the bolt holes have been monkeyed with. thanks for the heads up on the wobblies - seeing how this is my first endeavor with both those, and lug centric wheels. compound issue for me figuring this out. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:50 PM |
