Washer Stalk Question .. |
Literati914 |
Jun 11 2019, 10:51 AM
Senior Member Group: Members Posts: 1,428 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm gonna order the following items to convert over to an electric windshield washer system, but have some questions about the washer stalk on the column. With the stock set up, how many speeds are there for the wiper action? Is it JUST low and hi only, or is there a middle speed too? (too many years since my last 914 to remember, and it hardly ever rains, so..) Also, is there an intermittent action (I doubt), and is there a way to add it? Same question with the replacement stalk I'm considering (see link)?
https://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G and https://www.ebay.com/itm/BRAND-NEW-WINDSHIE...scAAOSw5ZBWPTnf . |
porschetub |
Jun 11 2019, 08:17 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'am pretty sure I ran a spare wire for my pump trigger to the relay I fitted,I cant remember if it was earth to the relay,I do remember I powered the relay of the fuseboard so would think the wire was an earth.
I see the pump shown is a knock-off by auction description anyway (IMG:style_emoticons/default/confused24.gif) ,the original is a 911 part and not expensive last time I checked,I used a generic VW one that works fine only cause I had in on hand. The OP must make sure the filler cap is blocked off but vented with a small hole. This is a "must do" if you have a 6 cyl with front cooler and spacesaver,in my case no cooler but wanted to drop some weight,plan is to move airpump/tools and alloy wheel to the rear. |
Lo-Fi Version | Time is now: 19th April 2024 - 10:06 PM |
