Washer Stalk Question .. |
Literati914 |
Jun 11 2019, 10:51 AM
Senior Member Group: Members Posts: 1,437 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I'm gonna order the following items to convert over to an electric windshield washer system, but have some questions about the washer stalk on the column. With the stock set up, how many speeds are there for the wiper action? Is it JUST low and hi only, or is there a middle speed too? (too many years since my last 914 to remember, and it hardly ever rains, so..) Also, is there an intermittent action (I doubt), and is there a way to add it? Same question with the replacement stalk I'm considering (see link)?
https://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G and https://www.ebay.com/itm/BRAND-NEW-WINDSHIE...scAAOSw5ZBWPTnf . |
Literati914 |
Jun 12 2019, 03:02 PM
.. If you want the intermittent relay, look for the same switch with 6 pins in the connector. The nice thing about the intermittent relay is that it will trigger your wipers for few seconds when you activate the pump. This is key info I've been looking to understand, thanks. Found it! Take a look here for all the info you need. http://www.914world.com/bbs2/index.php?s=&...t&p=1620396 Again, the switch should be the right one but the picture doesn't match the description. You need 6 pins plus the external black wire. So, this leaves me a bit confused still.. since your #12 post (in that thread) is a link to the very same lever/switch that I originally posted in this post... and thanks for pointing out that it only shows 5 pins. I sent a note to Cip1 but have not heard back from them. Interesting too, is that their description makes a comment on some models using 4 pin and some using 6 pin - however theirs is 5 !?!?!?!? |
Lo-Fi Version | Time is now: 25th April 2024 - 05:31 PM |
