Clutch adjustment issues !, needs to be adjusted again..something wrong ? |
porschetub |
Jun 11 2019, 07:28 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got the car out of storage for a startup and short drive yesterday,noticed the engagement point is high on the pedal (again),obviously isn't happy there,and not fun to drive this way.
Sometime back I shimmed the ball pivot as it was clear the throw out lever was contacting the gearbox casing...not by much but after measurement it appeared my flywheel had been resurfaced @ some stage but still in spec. Cable was new when I did the 6 conversion 708kms ago,and I cant find any movement in the tunnel tube,clutch is new and all wear parts replaced on the throw-out lever and bearing,have new 914rubber cable roller also. Really got me buggered this one ,why do I need to adjust it so often.....bad cable who knows. TIA |
Rand |
Jun 12 2019, 02:35 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Every lurker is wondering if the firewall crack is a thing.
porschetub |
Jun 12 2019, 03:07 PM
Every lurker is wondering if the firewall crack is a thing. No indication of that when last on a hoist to fix an oil leak,car has had little use since then except for running up the motor monthly. Keep the idea's coming however,I will make a checklist and go into it all,Perrys comment got me thinking about the dreaded roll pin ,nothing to say it hasn't broken after my pedal box rebush job (IMG:style_emoticons/default/confused24.gif) . (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th April 2024 - 06:34 AM |
