Clutch adjustment issues !, needs to be adjusted again..something wrong ? |
porschetub |
Jun 11 2019, 07:28 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Got the car out of storage for a startup and short drive yesterday,noticed the engagement point is high on the pedal (again),obviously isn't happy there,and not fun to drive this way.
Sometime back I shimmed the ball pivot as it was clear the throw out lever was contacting the gearbox casing...not by much but after measurement it appeared my flywheel had been resurfaced @ some stage but still in spec. Cable was new when I did the 6 conversion 708kms ago,and I cant find any movement in the tunnel tube,clutch is new and all wear parts replaced on the throw-out lever and bearing,have new 914rubber cable roller also. Really got me buggered this one ,why do I need to adjust it so often.....bad cable who knows. TIA |
porschetub |
Jun 11 2019, 10:12 PM
Thanks for the replies folks ;
Spoke was the cable new? I don't remember the brand I bought off Pelican but remember most use them,maybe I have a bad one ?. Perry,pedal assembly fully rebuilt and all good ,new bronze bushes and repaired the the flogged out clutch arm and replaced the clevis. Done the test on the tube and only slight deflection near the front in the tunnel,I do think the pedal is somewhat heavy however,is that telling me anything ????. Again thanks. |
bdstone914 |
Jun 13 2019, 07:42 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@ porschetub
' date='Jun 11 2019, 09:12 PM' post='2721801'] Thanks for the replies folks ; Spoke was the cable new? I don't remember the brand I bought off Pelican but remember most use them,maybe I have a bad one ?. Perry,pedal assembly fully rebuilt and all good ,new bronze bushes and repaired the the flogged out clutch arm and replaced the clevis. Done the test on the tube and only slight deflection near the front in the tunnel,I do think the pedal is somewhat heavy however,is that telling me anything ????. Again thanks. [/quote] Another member reported that a Terry cable had more drag and harder pedal. Seems they use larger wire strands. I woul have guessed it was a broken clutch tube. Can you see if the middle clutch tube support is in tact? A small mirror should let you see. Here is a cut -a - way of the tunnel showing the middle attachment. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 24th April 2024 - 12:41 PM |
