914/6 ignition switch woes, won't engage starter |
rudedude |
Jun 11 2019, 07:49 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
For a few years now the switch in my /6 has been declining in its ability to get past the run position to the start position. It can take upwards of 10 tries to engage starter. I finally ordered a new electrical portion believing that to be the issue. Now that i have the electrical part removed I see that the issue is in the mechanical part. Has anyone had one apart to see if they are repairable? Its now gone to a much more difficult fix removing shear pins and the switch than just the easy fix. Any help is much appreciated.
Thanks, Jule |
rudedude |
Jun 12 2019, 10:01 AM
I spoke with porsche dealer as this is supposedly a special order, ? keyed to your vin. Is it possible to change the tumbler assembly on a used one? Or am I stuck going with porsche? It is the same ignition interlock that is used in 911 up thru 98 I believe.
Thanks, Jule |
Lo-Fi Version | Time is now: 26th April 2024 - 01:57 AM |
