914/6 ignition switch woes, won't engage starter |
rudedude |
Jun 11 2019, 07:49 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
For a few years now the switch in my /6 has been declining in its ability to get past the run position to the start position. It can take upwards of 10 tries to engage starter. I finally ordered a new electrical portion believing that to be the issue. Now that i have the electrical part removed I see that the issue is in the mechanical part. Has anyone had one apart to see if they are repairable? Its now gone to a much more difficult fix removing shear pins and the switch than just the easy fix. Any help is much appreciated.
Thanks, Jule |
rudedude |
Jun 12 2019, 10:01 AM
I spoke with porsche dealer as this is supposedly a special order, ? keyed to your vin. Is it possible to change the tumbler assembly on a used one? Or am I stuck going with porsche? It is the same ignition interlock that is used in 911 up thru 98 I believe.
Thanks, Jule |
mb911 |
Jun 12 2019, 10:49 AM
914 Guru Group: Members Posts: 6,799 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I spoke with porsche dealer as this is supposedly a special order, ? keyed to your vin. Is it possible to change the tumbler assembly on a used one? Or am I stuck going with porsche? It is the same ignition interlock that is used in 911 up thru 98 I believe. Thanks, Jule Tweet can do it. He did mine took a while but he was rekeying everything and he was very busy. Make sure you call and talk to him. |
Lo-Fi Version | Time is now: 18th April 2024 - 01:09 PM |
